MediaWiki API help
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
list=logevents (le)
(main | query | logevents)
  • This module requires read rights.
  • Source: MediaWiki
  • License: GPL-2.0+
Get events from logs.
Parameters:
leprop
Which properties to get:
ids
Adds the ID of the log event.
title
Adds the title of the page for the log event.
type
Adds the type of log event.
user
Adds the user responsible for the log event.
userid
Adds the user ID who was responsible for the log event.
timestamp
Adds the timestamp for the log event.
comment
Adds the comment of the log event.
parsedcomment
Adds the parsed comment of the log event.
details
Lists additional details about the log event.
tags
Lists tags for the log event.
Values (separate with |): ids, title, type, user, userid, timestamp, comment, parsedcomment, details, tags
Default: ids|title|type|user|timestamp|comment|details
letype
Filter log entries to only this type.
One of the following values: Can be empty, or block, protect, rights, delete, upload, move, import, patrol, merge, suppress, tag, managetags, contentmodel, translationreview, translatorsandbox, newusers, pagetranslation
leaction
Filter log actions to only this action. Overrides letype. In the list of possible values, values with the asterisk wildcard such as action/* can have different strings after the slash (/).
One of the following values: protect/modify, protect/protect, protect/unprotect, block/block, block/reblock, block/unblock, contentmodel/change, delete/delete, delete/event, delete/restore, delete/revision, import/interwiki, import/upload, managetags/activate, managetags/create, managetags/deactivate, managetags/delete, merge/merge, move/move, move/move_redir, patrol/patrol, protect/move_prot, rights/autopromote, rights/rights, suppress/block, suppress/delete, suppress/event, suppress/reblock, suppress/revision, tag/update, upload/overwrite, upload/revert, upload/upload, translationreview/message, translationreview/group, translatorsandbox/promoted, translatorsandbox/rejected, newusers/tsbpromoted, newusers/newusers, newusers/create, newusers/create2, newusers/byemail, newusers/autocreate, pagetranslation/mark, pagetranslation/unmark, pagetranslation/moveok, pagetranslation/movenok, pagetranslation/deletelok, pagetranslation/deletefok, pagetranslation/deletelnok, pagetranslation/deletefnok, pagetranslation/encourage, pagetranslation/discourage, pagetranslation/prioritylanguages, pagetranslation/associate, pagetranslation/dissociate
lestart
The timestamp to start enumerating from.
Type: timestamp (allowed formats)
leend
The timestamp to end enumerating.
ledir
In which direction to enumerate:
newer
List oldest first. Note: lestart has to be before leend.
older
List newest first (default). Note: lestart has to be later than leend.
One of the following values: newer, older
Default: older
leuser
Filter entries to those made by the given user.
letitle
Filter entries to those related to a page.
lenamespace
Filter entries to those in the given namespace.
One of the following values: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 1198, 1199
leprefix
Filter entries that start with this prefix.
letag
Only list event entries tagged with this tag.
lelimit
How many total event entries to return.
No more than 500 (5,000 for bots) allowed.
Type: integer or max
Default: 10
lecontinue
When more results are available, use this to continue.
Example:
List recent log events.
api.php?action=query&list=logevents
