Stabi mode
From version 2.3. it is possible to activate the Stabi/Function in the two ways:
- Negative Gyro Gain
- Separate channel (NEW)
1 Negative Gyro Gain
Gyro Gain is still used to set the rudder gyro gain. At the same time, positive or negative value will determine if selected function is inactive or active. So it is important to set the gyro gain properly for both normal flight and selected function. Usually same, but opposite values are fine (+60% and -60%)
This is the common way how pilots are configuring the Gyro Gain. It can be easily programmed for a two-state switch. For the Rescue a momentary switch is the best. Usually you can find the configuration in the GYRO menu in your transmitter. For the beginning set:
- Position 0: 50% (normal flight)
- Position 1: -50% (selected function)
1.2 In the software
There is disadvantage that in order to activate selected function, you have to set a negative Rudder Gain. This can't be changed during the flight. On the other hand, you can use a Switching feature and program a different Function and Rudder Gain for each bank.
