Stabi mode
Revision as of 10:37, 3 February 2017 by Admin (Talk | contribs) (Separate channel)
Info.png It is possible to set a different functions between Banks.
From version 2.3. it is possible to activate the Stabi/Function in the two ways:
  • Negative Gyro Gain
  • Separate channel (NEW)
1 Negative Gyro Gain
Info.png Gyro Gain is still used to set the rudder gyro gain. At the same time, positive or negative value will determine if selected function is inactive or active. So it is important to set the gyro gain properly for both normal flight and selected function. Usually same, but opposite values are fine (for example +60%/-60%)
  • Position 0: 50% (normal flight)
  • Position 1: -50% (selected function)
Do not forget to set the gains accordingly for your model.
1.2 In the software
2 Separate channel
Function in the Stabi/Function parameter will be activated by a separate channel that selected in the General/Channels.
Configuration
  1. Open the General/Channels
  2. In the right part of the Channels window, select F: Stabi function.
Function indicator
  • 0 - function is inactive.
  • 1 - function is active.
