Stabi mode
From version 2.3. it is possible to activate the Stabi/Function in the two ways:
- Negative Gyro Gain
- Separate channel (NEW)
1 Negative Gyro Gain
Gyro Gain is still used to set the rudder gyro gain. At the same time, positive or negative value will determine if selected function is inactive or active. So it is important to set the gyro gain properly for both normal flight and selected function. Usually same, but opposite values are fine (for example +60%/-60%)
- Position 0: 50% (normal flight)
- Position 1: -50% (selected function)
1.2 In the software
1.3 Gyro vs Function
Function | Gyro gain | Gyro mode | Mode |
Disabled | 0 - 100% | Head-Lock | - |
Rescue (Normal) | 0 - 100% | Head-Lock | - |
Rescue (Acro) | 0 - 100% | Head-Lock | - |
Stabilisation (Normal) | 0 - 100% | Head-Lock | - |
Stabilisation (Acro) | 0 - 100% | Head-Lock | - |
Stabilisation (Scale) | 0 - 100% | Head-Lock | - |
Coaxial | 0 - 100% | Head-Lock | - |
Disabled | -100% - 0% | Normal (Rate) | - |
Rescue (Normal) | -100% - 0% | Head-Lock | Rescue |
Rescue (Acro) | -100% - 0% | Head-Lock | Rescue |
Stabilisation (Normal) | -100% - 0% | Head-Lock | Stabilisation |
Stabilisation (Acro) | -100% - 0% | Head-Lock | Stabilisation |
Stabilisation (Scale) | -100% - 0% | Normal (Rate) | Stabilisation |
Coaxial | -100% - 0% | Head-Lock | Stabilisation |
2 Separate channel
Function in the Stabi/Function parameter will be activated by a separate channel that selected in the General/Channels.
- Channel configuration
- Open the General/Channels.
- Function indicator
- 0 - function is inactive.
- 1 - function is active.
Gyro Gain can still change gyro mode (Head-Lock or Normal), but will not activate the Function in this configuration.
2.1 Gyro mode vs Function
