Translations:YGE ESC RPM output/43/en
Revision as of 02:41, 18 February 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
By default YGE controllers are programmed to 1100μs - 1900μs Throttle Range. This is same as the default range of the Spirit. If Throttle was not calibrated yet, you can leave all the settings untouched. Then it will match with no modification.
