Normál (Rate)
Revision as of 11:29, 21 February 2017 by Spiritdm (Talk | contribs)
V normálním režimu gyro vrtulky kompenzuje výchylku v ose z. Tento režim je obvykle nazýván Rate mód. Narozdíl od režimu Head-Lock nedrží striktně výchylku. To znamená, že vrtulka může ujíždět.
1 Drifting
When hovering, drifting should not occur if the rudder mechanics has correctly configured neutral position. But in case of a wind, the drift can occur. This mode is suitable only for forward flight.
2 Aktivace
To activate this mode set the Gyro Gain to a negative value. To be sure that the mode is active, open the Diagnostic tab. Gyro Bar should display N when Normal mode is active. This mode can work only when Stabi/Function parameter is set to Disabled.
3 Usage
If you want to set the rudder mechanic precisely, we recommend to use this mode. Simply activate the mode during hovering and observe if there is any drift. If there is a drift, then it mean that the rudder neutral position is not configured well. Try to change push rod length of the rudder control mechanics to compensate this drift. This configuration can greatly improve performance of the rudder including stopping behavior.
