Stabilizace (Maketa)
Revision as of 15:42, 1 March 2017 by Admin (Talk | contribs) (Created page with "Vlastnosti")
Stabilizační režim je funkce jednotky, která pomáhá pilotovi udržovat model v rovině. Model je plně pod kontrolou pilota, ale na rozdíl od běžného režimu letu má tendenci vracet se automaticky do horizontu.
Režim lze aktivovat na dálku příslušným přepínačem vašeho vysílače. Stabilizace bude fungovat tak dlouho, jak dlouho bude přepínač v aktivní poloze. V opačném případě se model vrátí do běžného letového režimu.
1 Vlastnosti
  • Upon activation of the Stabilisation (Scale), the model will attain horizontal level rather slowly (Always skids down).
  • Cyclic stick input from the pilot will tilt the model to a degree which can be configured by Direction control rate parameter.
  • It is perfect for learning basic transitions and stationary hovering.
  • In this mode it is impossible to perform a flips or rolls. This mean that this mode is not suitable for learning acrobatics.
  • Collective pitch is controlled by the pilot as in a normal flight mode.
  • Rudder gyro is in the Normal (Rate) mode.
Info.png This mode will not maintain altitude or a spot on position. It can make hovering noticeable easier.
2 Setttings
To make it comfortable for your needs you can set the Direction control rate parameter. This will affect how the helicopter will respond to the sticks.
  • Low values are recommended for beginners - it will return faster to the horizontal position and not allow tilting to a high angle.
  • Higher values will allow to tilt the model to a higher angle and to achieve faster flight speed.
