Graupner SUMD/es
Revision as of 21:14, 11 March 2017 by Gotas (Talk | contribs) (Created page with "Ajustes de spirit")
Con graupner hott radios se puede utilizar totalmente digital, de una sola línea smud protocolo. Para la conexión sólo se requiere cable de servo normal.
1 cableado
Conecte el cable de acuerdo a la foto. En la unidad el cable está en el puerto raíz. En el receptor es siempre el último canal. Para gr-12 / gr-12l se emite con la etiqueta "" 6 "".
Info.png Tenga en cuenta que el cable de señal (naranja) está en la parte inferior del receptor.
Si no ha conectado una fuente de alimentación, puede conectar el cable de bec o 1-2s lipo ahora (incluso sin un servo).
Warning.png Nunca conecte una fuente de alimentación a los puertos sys o ele / pit / ail!
2 Ajustes de spirit
After initialization of the unit you can start the software. To allow the connection set the Receiver type to SRXL/SUMD in the General tab.
Now save the settings (CTRL+S) or in the Backup tab/Unit - Save.
3 Receiver configuration
By default SUMD transmission is disabled in the HoTT receivers. It is necessary to enable it in the (F) Function/Telemetry/Setting & Data View menu (HoTT MZ series).
Change SUMD at CH6 to YES.
4 Usage
Now you can restart the unit. After the initialization the SUMD connection will work. Reverse of some channels might be necessary depending on the radio model - please check the Diagnostic tab.
The transmission is able to carry all the channels. Usually SUMDOF12 option (if available) is fine.
Info.png For MX-12/MZ-12 transmitters it is needed to change the channel mapping in the Spirit Settings. Please go to the General tab/Channels and change Gyro Gain to Channel 7.
