Translations:Futaba Telemetry/67/en
Revision as of 13:47, 17 August 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
The FrSky Integration cable is not able to carry power to the receiver. For this purpose you will need to add a normal servo cable between receiver and unit to a free port (for example AUX, AUX2 or CH0 port connected with 8/SB). Alternatively you can use one additional wire and connect it to the middle pin of the RUD that is not connected. You can also use a secondary BEC output so no other cable is required.
