Connexion Spektrum PWM
Revision as of 18:41, 20 November 2017 by GoblinShefford (Talk | contribs) (Created page with "Unité")
Ce tableau décrit la connexion du récepteur Spektrum AR610. Parce que les étiquettes sont les mêmes entre les autres récepteurs, vous pouvez également l'utiliser pour d'autres récepteurs AR.
Câblage PWM
Unité | RECEIVER |
RUD | RUDD |
AUX | GEAR |
ELE/PIT/AIL | ORANGE wire to AILE RED wire to AUX 1 BROWN wire to ELEV |
Servo connectors are connected always with Orange wire closer to the labels (in the receiver and unit as well).
Special cable which ends with 3 servo connectors must be connected in the way, that these wires are always closer to the port labels.
- ESC should be connected to the THRO port.
- If External BEC is used, you can connect it to a free port in the receiver.
