Stabi mode
Revision as of 19:06, 23 January 2018 by FuzzyBot (Talk | contribs) (Updating to match new version of source page)
Info.png It is possible to set a different functions between Banks.
From version 2.3.0 it is possible to activate the Stabi/Function in the two ways:
  • Negative Gyro Gain
  • Separate channel (NEW)
1 Negative Gyro Gain
Info.png Gyro Gain is still used to set the rudder gyro gain. At the same time, positive or negative value will determine if selected function is inactive or active. So it is important to set the gyro gain properly for both normal flight and selected function. Usually same, but opposite values are fine (for example +60%/-60%)
  • Position 0: 50% (normal flight)
  • Position 1: -50% (selected function)
1.2 In the software
1. First step
2.Second step
1.3 Function vs Gyro
Function Gyro gain Gyro mode Mode
Disabled 0 - 100% Head-Lock -
Stabilisation (Scale) 0 - 100% Head-Lock -
Coaxial 0 - 100% Head-Lock -
2 Separate channel
Channel configuration
  1. Open the General/Channels.
Function indicator
  • 0 - function is inactive.
  • 1 - function is active.
Info.png Gyro Gain can still change gyro mode (Head-Lock or Normal).
2.1 Function vs Channel
Function Channel Mode
Disabled -100% - 0% -
Rescue (Normal) -100% - 0% -
Rescue (Acro) -100% - 0% -
Stabilisation (Normal) -100% - 0% -
Stabilisation (Acro) -100% - 0% -
Stabilisation (Scale) -100% - 0% -
Coaxial -100% - 0% -
Disabled 0 - 100% -
Rescue (Normal) 0 - 100% Rescue
Rescue (Acro) 0 - 100% Rescue
Stabilisation (Normal) 0 - 100% Stabilisation
Stabilisation (Acro) 0 - 100% Stabilisation
Stabilisation (Scale) 0 - 100% Stabilisation
Coaxial 0 - 100% Stabilisation
2.2 Function vs Gyro
