Translations:Unequal Collective Pitch/4/en
Revision as of 10:34, 9 April 2018 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
Collective Centering
- Put your Pitch stick at the center as close as possible.
- Verify what value you can see in the Diagnostic tab at the Pitch bar.
- Make sure you will see 0%. If value is different by more than +/- 2% it is recommended to use the Subtrim function in your transmitter and adjust Pitch channel to achieve 0%.
