Translations:Tuning Guide/22/en
Revision as of 13:20, 12 April 2018 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
Set the Sensor/Rotation Rate parameter to the extent that flips and rolls are fast enough. Be carefull to not set it higher than your mechanics can handle. The highest value for the most models is between 11 - 13. If the value is too high, steering is not precise and sometimes you can observe that rate is not constant (Once you finish the cyclic input it will continue for a fraction of second).
