Режим стабилизации
Что бы включить режим спасения необходимо установить желаемый параметр Стабилизация/Функция. При значении Отключено никакая функция стабилизации не используется.
Начиная с версии 2.3.0 есть возможность активировать стабилизацию двумя способами:
- Отрицательным значением чувствительности хвоста
- Отдельным каналом (Новое)
1 Отрицательная чувствительность гироскопа
Gyro Gain is still used to set the rudder gyro gain. At the same time, positive or negative value will determine if selected function is inactive or active. So it is important to set the gyro gain properly for both normal flight and selected function. Usually same, but opposite values are fine (for example +60%/-60%)
- Position 0: 50% (normal flight)
- Position 1: -50% (selected function)
1.2 In the software
1.3 Function vs Gyro
Function | Gyro Gain | Gyro Mode | Flight Mode |
Disabled | 0 - 100% | Head-Lock | - |
Rescue (Normal) | 0 - 100% | Head-Lock | - |
Rescue (Acro) | 0 - 100% | Head-Lock | - |
Stabilisation (Normal) | 0 - 100% | Head-Lock | - |
Stabilisation (Acro) | 0 - 100% | Head-Lock | - |
Stabilisation (Scale) | 0 - 100% | Head-Lock | - |
Coaxial | 0 - 100% | Head-Lock | - |
Disabled | -100% - 0% | Normal (Rate) | - |
Rescue (Normal) | -100% - 0% | Head-Lock | Rescue |
Rescue (Acro) | -100% - 0% | Head-Lock | Rescue |
Stabilisation (Normal) | -100% - 0% | Head-Lock | Stabilisation |
Stabilisation (Acro) | -100% - 0% | Head-Lock | Stabilisation |
Stabilisation (Scale) | -100% - 0% | Normal (Rate) | Stabilisation |
Coaxial | -100% - 0% | Head-Lock | Stabilisation |
2 Separate channel
- Channel configuration
- Open the General/Channels.
- Function indicator
- 0 - function is inactive.
- 1 - function is active.
Gyro Gain can still change gyro mode (Head-Lock or Normal). Positive Gyro Gain value will activate Head-Lock mode always. Active Function and Gyro mode is always visible in the Diagnostic tab.
2.1 Function vs Channel
- Flight Mode "-" mean that the function is inactive and a normal flight regime is on.
Function | Channel | Gyro Mode | Flight Mode |
Disabled | -100% - 0% | Head-Lock / Normal | - |
Rescue (Normal) | -100% - 0% | Head-Lock | - |
Rescue (Acro) | -100% - 0% | Head-Lock | - |
Stabilisation (Normal) | -100% - 0% | Head-Lock | - |
Stabilisation (Acro) | -100% - 0% | Head-Lock | - |
Stabilisation (Scale) | -100% - 0% | Head-Lock / Normal | - |
Coaxial | -100% - 0% | Head-Lock | - |
Disabled | 0 - 100% | Head-Lock / Normal | - |
Rescue (Normal) | 0 - 100% | Head-Lock | Rescue |
Rescue (Acro) | 0 - 100% | Head-Lock | Rescue |
Stabilisation (Normal) | 0 - 100% | Head-Lock | Stabilisation |
Stabilisation (Acro) | 0 - 100% | Head-Lock | Stabilisation |
Stabilisation (Scale) | 0 - 100% | Head-Lock / Normal | Stabilisation |
Coaxial | 0 - 100% | Head-Lock | Stabilisation |
