SpiritRS Preparation
Revision as of 12:04, 2 June 2020 by Admin (Talk | contribs)
To operate Spirit RS unit any JETI DUPLEX radio can be used.
Supported radios are:
  • DC-14
  • DC-16
  • DC-16 II
  • DC-24
  • DS-12
  • DS-14
  • DS-16
  • DS-24
We recommend to start with clear model profile as you will need only few changes.
Spirit System offer DS-12 radio tailored specially for the Spirit RS. This mean you will be able to utilize completely all features out of the box.
1 Beginning
2 Turning On and Off
3 New Profile
3.1 Profile creation
In the Basic Properties menu select Heli to Spirit and continue to another page. (Please note transmitter update 5.03 is required for this option).
3.2 Basic Helicopter settings
3.2.1 Flight Modes
Assign switch for Autorot. mode - usually it is two-state switch called Sc at the left front side of the radio. This switch will be used for Throttle Hold/Autorotation.
Assign switch for all Idle modes - usually it is tri-state switch called Sa above Sc.
