Futaba
Revision as of 10:28, 25 August 2020 by PSzakra (Talk | contribs) (Created page with ":*Az IDLEUP2-n2k az alábbiak szerint kell állni: :::OFF :::OFF :::ON")
Telepítési útmutató
a
T8FG vagy kompatibilis
✔Repülési módok
✔Gyro érték beállítása
✔Normal (Sebességű) mód
✔Mentés és Stabilizáció
✔Bank Váltás
1 Repülési Mód beállítása
Lépjen a MDL → CONDITION elemre
Állítsa be az SE, Repülési mód kapcsolót az IDLEUP1 és az IDLEUP2 számára.
  • Győződjön meg arról, hogy az IDLEUP1 BE/KI konfigurálása a következő módon történik:
OFF
ON
OFF
  • Az IDLEUP2-n2k az alábbiak szerint kell állni:
OFF
OFF
ON
  • IDLEUP3 will be used for the Rescue/Stabilisation modes. For this purpose we will create special flight mode that will be activated when momentary switch SH is pressed.
Configure SH switch for IDLEUP3 with following ON/OFF:
OFF
ON
  • Hold can be configured for SF switch with ON/OFF values:
OFF
ON
Final CONDITION screen after the settings:
Check priorities for correct behavior – Hold has the highest priority.
Warning.png Remember to set Throttle and Pitch Curves for NORMAL, IDLEUP1, IDLEUP2 and IDLEUP3 modes.
For IDLEUP3 configure higher RPM if you wish to use the rescue mode, because after activation, throttle curve will be changed too.
2 Gyro Gain setup
Go to MDL → GYRO
Gyro switching has to be performed through configured flight modes – separate gyro gain for each mode. Select COND type instead of SW in the menu.
a) Select HOLD, then set TYPE GY AVCS with RATE 60% for the beginning. That mean that Gyro Gain will be +60% when Hold is active. AVCS mode is Head Lock gyro mode for Spirit
b) For NORMAL, IDLEUP1 and IDLEUP2, set TYPE GY AVCS with RATE 60% for the beginning. That mean that Gyro Gain will be +60% when these flight modes are active.
c) For IDLEUP3, set TYPE GY NORMAL with RATE 60% for the beginning. That mean that Gyro Gain will be ­60% when SH is active. So this will activate Normal (Rate) Gyro mode with default settings in the unit. If Stabi/Function is not Disabled, then special mode will be activated with Head Lock Gyro mode, while Gyro Gain can be still configured.
d) Make sure that you will configure Gyro Gain in this menu for each Flight mode according to your RPM.
3 Bank Switching setup
Go to LNK → FUNCTION
Set channel 7 AUX1 to SG switch.
In the settings of the unit go to General/Channels and assign Bank function to Channel 7.
Bank switching will be performed with SG tri­state switch.
For Bank 0 you can configure for example Rescue (acro).
For Bank 1 you can configure Stabilisation mode.
For Bank 2 you can set Disabled so Normal/Rate Gyro mode can be activated.
