Translations:Imprecise Rescue/4/en
Revision as of 09:52, 11 September 2020 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
- Very important is to check, whether the Position and the Swashplate parameters are configured correctly. If not, these modes can't operate properly. Make sure that in the Diagnostic tab all directions correspond with a real stick movement.
- Check if the unit is aligned in all 3 axes. Alignment error should be approx. in 1° range or less. You should mount the unit precisely in respect to the helicopter' frame. Use only one provided adhesive tape. The unit should not flex or move in any way - mounting should be rock solid.
- Rescue and Stabilisation can work in nearly any condition. But in case that your Vibrations are exceptionally high it can't be guaranteed. You can check vibrations with Spectral Analysis in the software, especially Y - Aileron axis, where there are mostly the highest.
- Helicopter is equipped with a cooling fan that is producing ultrasound frequency. Fans from HobbyWing ESCs are known for this. This has a great impact on the precision of Rescue and Stabilisation modes.
