Translations:Configuration/111/es
Revision as of 12:29, 19 September 2016 by Zexx86 (Talk | contribs) (Created page with "Con el fin de averiguar qué parte del modelo está causando las vibraciones no deseadas, mover el cursor a la cima y comprobar la velocidad de la cabeza (RPM). La velocidad d...")
