Translations:Configuration/129/es
Revision as of 12:55, 19 September 2016 by Zexx86 (Talk | contribs) (Created page with "En el caso de un problema importante que ocurra durante el vuelo 20px la de registro se guarda de forma permanente en la memoria de la unidad y permanece allí...")
