Cablaggio SpiritRS
Revision as of 16:40, 13 January 2021 by DaniloB (Talk | contribs) (Created page with "* '' 'CH1' '' e '' 'CH3' '' - Servo Alettoni / Passo * '' 'CH2' '' - Servo dell'elevatore * '' 'CH4' '' - Servo di coda")
Spirit RS con l'attuale firmware ha il supporto per 3x piatto oscillante, 1x coda e 1x servomotore. Ha anche 2x porte di telemetria DUPLEX indipendenti, il che significa che puoi collegare direttamente due sensori JETI. Inoltre è possibile collegare opzionalmente un ricevitore di backup.
Inoltre puoi utilizzare la telemetria ESC.
1 Cablaggio Servo
Secondo gli schemi seguenti è possibile collegare i servi allo Spirit RS. Se alcuni dei tuoi servi non hanno un impulso centrale di 1520μs, connetti il servo più tardi durante il processo di installazione guidata.
  • 'CH1' e 'CH3' - Servo Alettoni / Passo
  • 'CH2' - Servo dell'elevatore
  • 'CH4' - Servo di coda
Depending on your model and selected Swashplate Type servos are wired differently. Wiring is described in the following sections and also in the Setup Wizard.
1.1 Elevator at the front
Elevator has servo control push rod at the front part of the model - swashplate push rod at the front.
  • CH1 - connected to the right servo (Pitch)
  • CH3 - connected to the left servo (Aileron)
1.2 Elevator at the rear
Elevator has servo control push rod at the rear - swashplate push rod at the rear.
  • CH1 - connected to the left servo (Aileron)
  • CH3 - connected to the right servo (Pitch)
2 Power Supply
Power Supply is critical part of the model. For this reason it is highly recommended to use suitable BEC or battery that can handle used servos. Once wiring and setup is completed it is highly advised to perform the BEC test. If the test will not pass it is clear the power supply is inadequate and failure will occur.
BEC, Battery or Backup power supply should be connected always at THR, E1 and AUX ports.
  • THR - used for Throttle output and primary ESC/BEC cable for electric helicopters. For a combustion helicopters THR port is used for Throttle Servo.
  • E1 - used for Secondary BEC cable for electric helicopters (recommended for class 500+). For a combustion helicopters E1 port is used for a Battery lead.
  • AUX - used for Optional Power Guard system or an additional battery lead. Can output also channel data for controlling a landing gear, lights, etc.
Warning.png Do not connect any wire to E2 pin. This pin is shared between Spirit and internal receiver. It is used for future purposes. Improper utilization of the E2 pin can result in loss of control!
