Датчик оборотов Spirit
Revision as of 10:00, 12 July 2022 by Gstatopen (Talk | contribs) (Created page with "Оранжевый провод: Выход сигнала оборотов")
čeština • ‎Deutsch • ‎English • ‎español • ‎français • ‎italiano • ‎русский
Этот датчик Холла считывает обороты через вращающиеся магниты. Обычно 1 - 2 магнита смонтированы на вентиляторе нитро вертолета.
Подключения
Red wire: 3.3V - 15V
Brown wire: Ground (GND/-)
1 Wiring Example
Powering Lead with Red and Brown wires can be plugged to any free port with a BEC voltage. Signal Lead with Orange wire must be plugged always at the middle Pin of the ELE/PIT/AIL port (Spirit 1, Spirit Pro, Spirit 2, Spirit GT) or EXT/RPM/E2 port (Spirit RS and Spirit GTR).
2 Magnet mounting
We highly recommend to orientate each magnet as Active for a proper operation. More magnets will result in a higher reading resolution thus increased readout precision.
3 Governor Settings
When sensor is connected you can optionally use Spirit Governor. Please set the Sensor Divider parameter so that the value will represent count of the active magnets. Usually it is 1 or 2 magnets.
