Governor
Revision as of 23:35, 8 January 2017 by Admin (Talk | contribs) (Created page with "== Preparation == The governor from the Spirit unit (so called External governor) can be used with all single line digital receiver connections. This mean that for PWM and PP...")
Preparation
The governor from the Spirit unit (so called External governor) can be used with all single line digital receiver connections. This mean that for PWM and PPM it cannot be used. To make it work, you will need to get a RPM Sensor which can supply the unit with current RPM data. Then you will need :)
