Translations:Jeti Integration/22/en
Revision as of 05:09, 16 January 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
You can copy it by connecting the micro USB cable to the transmitter similarly as to an USB flash drive. When cable is attached to the transmitter you have to confirm the USB connection. Then simply drag and drop it to the Devices directory as you are used to.
