Translations:OpenTX Integration/50/en
Revision as of 06:07, 17 January 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
If the Menu will not load any parameter value, it is likely that the integration cable is connected improperly. If you use any Telemetry sensor, we recommend to disconnect it (at least from signal line) and verify again.
