Первый полет
Revision as of 09:42, 15 October 2018 by Gstatopen (Talk | contribs) (Created page with "Мы рекомендуем для первого полета установить Чувствительность хвоста = 50% (Для диапазона -100 / +100)...")
Если вы уверены, что Spirit настроен правильно, вы готовы к первому полету.
Мы рекомендуем для первого полета установить Чувствительность хвоста = 50% (Для диапазона -100 / +100). Это установит режим Head-Lock (удержание хвоста) с умеренной величиной удержания.
1 PRE-FLIGHT CONTROL
- Turn on the transmitter and connect the battery to the model.
- Wait for the initialization, the swashplate jumps.
- Tilt the model, ensure the swashplate is compensating in the correct direction on all axes.
- Move the tail boom in any direction, the tail slider/rudder blades should compensate in the opposite direction.
- Check that input from the transmitter sticks moves the swashplate and tail in the correct directions.
- Place the model on a flat surface, use the transmitter sticks to level the swashplate if it isn't already, the tail slider should be approximately in the center of its travel range.
If you encounter a problem or something appears wrong at this point, do not try to take off!
2 TAKEOFF
- Spool up the main rotor to the desired speed - we recommend to start with a slightly lower RPM.
- Slowly increase the collective pitch from zero.
- Try to steer the rudder and check whether it has sufficient gain and stop performance is good.
- If control is not very precise, slowly add cyclic and rudder gain as needed.
3 TUNING
Once you have finished the first flight and you want to achieve the optimal settings, please check the Tuning Guide.
