Installation
Die ordnungsgemäße Montage des Spirits spielt eine wichtige Rolle für den korrekten Betrieb Ihres Modells.
Finden Sie einen passenden Ort, an dem die Vibrationen so niedrig wie möglich sind – dies ist normalerweise die Stelle, die vom Hersteller zur Befestigung des Kreisels angegeben wird.
It is VERY important that the unit will be mounted so that the unit is exactly perpendicular to each rotational axis. Depending on your preference and available space it can be mounted in eight different positions:
- Horizontal (0°)
- Horizontal (180°)
- Horizontal (0° + inverted)
- Horizontal (180° + inverted)
- Vertical (0° - left side)
- Vertical (180° - left side)
- Vertical (0° - right side)
- Vertical (180° - right side)
In order to better insulate against any vibrations from the model, it is necessary
to choose the right double-sided mounting tape. The tape should limit any
transmission of vibrations from the model to the Spirit which may produce
undesirable flight characteristics.
Vibrations may also be caused by incorrectly balanced blades, damaged
bearings, bent shafts and other mechanical issues.
