Stabi-Modus
Revision as of 17:14, 17 February 2017 by Buell47 (Talk | contribs) (Created page with "Stabi-Modus")
Info.png It is possible to set a different functions between Banks.
From version 2.3. it is possible to activate the Stabi/Function in the two ways:
  • Negative Gyro Gain
  • Separate channel (NEW)
1 Negative Gyro Gain
Info.png Gyro Gain is still used to set the rudder gyro gain. At the same time, positive or negative value will determine if selected function is inactive or active. So it is important to set the gyro gain properly for both normal flight and selected function. Usually same, but opposite values are fine (for example +60%/-60%)
  • Position 0: 50% (normal flight)
  • Position 1: -50% (selected function)
1.2 In the software
1. First step 2.Second step
1.3 Function vs Gyro
Function Gyro gain Gyro mode Mode
Disabled 0 - 100% Head-Lock -
Stabilisation (Scale) 0 - 100% Head-Lock -
Coaxial 0 - 100% Head-Lock -
2 Separate channel
Channel configuration
  1. Open the General/Channels.
Function indicator
  • 0 - function is inactive.
  • 1 - function is active.
Info.png Gyro Gain can still change gyro mode (Head-Lock or Normal).
2.1 Function vs Channel
Function Channel Mode
Disabled 0 - 100% -
Rescue (Normal) 0 - 100% -
Rescue (Acro) 0 - 100% -
Coaxial 0 - 100% -
Disabled -100% - 0% -
2.2 Function vs Gyro
