HobbyWing Platinum ESC v3/v4 RPM output
HobbyWing ESCs v3/v4 are equipped with RPM lead that is providing signal for the external governor. So you do not need to do anything else except connect the cables properly and turn off the internal Governor of the ESC.
1 Required modification
For usage with the Spirit units a small modification of the RPM cable is needed.
- Move the Yellow cable to the middle in the Servo connector.
- You can do so with a needle easily.
- Wire layout
- Yellow wire: RPM Output Signal (PIT pin)
- White wire: Throttle signal (AUX port)
- Red wire: BEC Voltage (AUX port)
- Black wire: Ground (AUX port)
2 Governor Settings
- Throttle Frequency: 120Hz.
- Throttle Range - Min.: 1100 us.
