CC Phoenix Edge RPM Ausgang
Revision as of 15:22, 9 May 2018 by Buell47 (Talk | contribs) (Created page with "Erforderliche Änderung")
Castle Creations Phoenix ESCs sind mit einem RPM-Kabel ausgestattet, das das Signal für den externen Regler liefert. Sie müssen also nichts anderes tun, als die Kabel richtig anzuschließen und den internen Regler des ESC abzuschalten.
1 Erforderliche Änderung
For usage with the Spirit units a small modification of the RPM cable is needed.
  • Move the White cable to the middle in the Servo connector.
  • You can do so with a needle easily.
Wire layout
White wire: RPM Output Signal (PIT pin)
Yellow wire: Throttle signal (AUX1 port)
Red wire: BEC Voltage (AUX1 port)
Brown wire: Ground (AUX1 port)
2 Changing ESC settings
It is very important to change ESC mode so that internal Governor is disabled. This can be done by Castle Link software.
3 Governor Settings
  • Throttle Frequency: 60Hz.
