Caracteristicas GeoLink
Revision as of 21:23, 18 January 2019 by Gotas (Talk | contribs) (Created page with "como funciona")
GEOLINK ofrece una variedad de caracteristicas que pueden habilitarse bajo demanda mientras se vuela.Algunos tambien se pueden combinar para ofrecer la experiencia que desea
1 TTFF Acelerador
Esta caracteristica permite reducir significativamente el periodo en el que el modulo GEOLINK puede arreglar a los satelites de navegacion. Con algunos dispositivos lleva incluso unos minutos.Con GEOLINK este periodo se puede reducir a solo 6 segundos,mientras no se necesita respaldo de bateria.
1.1 como funciona
When module is powered up for the first time at a given day it is trying to find a satellites. It will do so in a normal way (without any time reduction). With GeoLink this should be between 20 - 35 seconds normally (depending on conditions).
Right after the flight and next power up this period is reduced significantly. When powering up within few minutes to hours you can always notice the time required for Fix is shortened.
1.2 How can it help me?
2 Logging
2.1 Logging specification
  • Up to 1.5 hour
  • Up to 63 logged flights
  • Recording period: 1 second
2.2 What is being logged?
  • Position on Earth: Latitude and Longitude
  • Altitude: relative altitude from starting point
  • Speed: flying speed of the model
  • Heading: direction in which model is flying
  • Date and time
2.3 Log viewer
2.4 Log backup and sharing
3 Return To Home
  • in the Spirit Settings by choosing the best spot at the map
  • by transmitter command being at the place considered as a new Home.
3.1 Description
3.2 With Altitude Hold
4 Auto Landing
4.1 Description
5 Position Hold
5.1 Description
5.2 With Altitude Hold
6 Geo-fence
6.1 Description
6.2 With Altitude Hold
7 Altitude Hold
7.1 Description
8 Altitude Limit
8.1 Description
