Montaje GeoLink
Revision as of 15:45, 19 January 2019 by Gotas (Talk | contribs) (Created page with "El montaje correcto es lo mas importante para lograr una condicion operativa optima.Si se realiza correctamente, GEOLINK no podra trabajar con gran precision, o en el peor de...")
El montaje correcto es lo mas importante para lograr una condicion operativa optima.Si se realiza correctamente, GEOLINK no podra trabajar con gran precision, o en el peor de los casos,alguna funcionalidad podria ser incluso inutilizable
1 Mounting on your helicopter
  • Horizontal (0°) - connector is pointing to main rotor
  • Horizontal (180°) - connector is pointing to tail rotor
1.1 Where to mount
  • It has clear sky visibility
  • It is perfectly horizontally aligned
Choose a position which is not too far, so that provided cable is long enough. Placing module too far on the boom could lead to bad Center of Gravity of the model.
1.2 How to mount
Warning.png Never mount GeoLink directly on a thick metallic parts, near a motor or any servo.
Warning.png Do not cover GeoLink connector with any tape, glue or paint. Opening above the connector is used to determine ambient pressure and altitude.
1.4 Unmounting
1.5 Mounting examples
1.5.1 LYNX Oxy 2
LYNX Oxy 2
1.5.2 KDS Chase 360
KDS Chase 360
KDS Chase 360
KDS Chase 360
1.5.3 SAB Goblin 700
SAB Goblin 700
SAB Goblin 700
2 Wiring
μSpirit SAT - Satellite port
Spirit Primary satellite port
Wiring with Spirit Pro unit.
3 Alignment
3.1 Alignment procedure
  2. Power up the Spirit unit.
