Governor
The governor from the Spirit unit (so called External governor) can be used with all single line digital receiver connections. This mean that for PWM and PPM it cannot be used. To make it work, you will need to get a RPM Sensor which can supply the unit with current RPM data.
- 1 Wiring
- 2 List of tested sensors
- 3 Activation
- 4 Spirit Settings
- 9 Governor Setup Procedure
- 10 First start
- 11 Autorotation Bailout
- 12 Throttle Hold for Autorotation (optional)
- 13 Troubleshooting
1 Wiring
1.1 Throttle
For usage of this governor it is necessary to connect the throttle (ESC or the Throttle servo) in the AUX (AUX1) port.
1.2 RPM signal
To make the governor work well it is very important to choose an appropriate RPM sensor. The following are known to work well.
Cable that carry RPM signal must be always connected when Governor is used.
Connect RPM signal cable to the pin of the unit:
- μSpirit - P pin - pin in the middle of P/E/A port
- Spirit Pro and Spirit 2 - PIT pin - pin in the middle of ELE/PIT/AIL port
- Spirit RS - RPM pin - pin in the middle of EXT/RPM/E2 port
Sensor can be powered from any available Satellite port (SAT) or directly from a BEC. Satellite port is giving 3.3V, while BEC is operating usually at 5 - 8V.
1.3 Wiring example
- Electric Motors
- HobbyWing Platinum ESC v3/v4 RPM output
- YGE ESC RPM output
- CC Phoenix Edge RPM output
- Scorpion Commander V RPM output
- HobbyWing RPM Sensor
- Hyperion RPM Sensor
- Orange RPM Sensor
- Nitro and Gasser Motors
3 Activation
First from all basic settings are necessary so the governor can control the head speed correctly. Please review all the parameters prior any configuration.
Fine-Tuning - Holding Limit
6.1 ESC Throttle Calibration
6.2 ESC setup
- Governor Response: 5
- Holding Performance: 1
10 First start
13 Troubleshooting
- RPM signal was lost.
