GeoLink Funktionen
Revision as of 12:28, 18 March 2021 by WilhelmL (Talk | contribs) (Created page with "Wenn das Modul zum ersten Mal eingeschaltet wird, versucht es, Satelliten in der Nähe zu finden. Dies geschieht ohne jeglicher Zeitverkürzung und sollte beim GeoLink normale...")
1 TTFF Beschleuniger
1.1 Wie es funktioniert
Right after the flight and next power up this period is reduced significantly. When powering up within few minutes to hours you can always notice the time required for Fix is shortened.
1.2 How can it help me?
2 Logging
2.1 Logging specification
  • Up to 1.5 hour
  • Up to 63 logged flights
  • Recording period: 1 second
2.2 What is being logged?
  • Position on Earth: Latitude and Longitude
  • Altitude: relative altitude from starting point
  • Speed: flying speed of the model
  • Heading: direction in which model is flying
  • Date and time
2.3 Log viewer
2.4 Log backup and sharing
3 Return To Home
  • in the Spirit Settings by choosing the best spot at the map
  • by transmitter command being at the place considered as a new Home.
3.1 Description
3.2 With Altitude Hold
4 Auto Landing
4.1 Description
5 Position Hold
5.1 Description
5.2 With Altitude Hold
6 Geo-fence
6.1 Description
6.2 With Altitude Hold
7 Altitude Hold
7.1 Description
8 Altitude Limit
8.1 Description
