GeoLink Funktionen
Revision as of 12:29, 18 March 2021 by WilhelmL (Talk | contribs) (Created page with "Gleich nach dem Flug und dem nächsten Einschalten wird diese Zeitspanne erheblich verkürzt. Beim Einschalten innerhalb weniger Minuten (Akkuwechseln) bis Stunden können sie...")
1 TTFF Beschleuniger
1.1 Wie es funktioniert
1.2 How can it help me?
2 Logging
2.1 Logging specification
  • Up to 1.5 hour
  • Up to 63 logged flights
  • Recording period: 1 second
2.2 What is being logged?
  • Position on Earth: Latitude and Longitude
  • Altitude: relative altitude from starting point
  • Speed: flying speed of the model
  • Heading: direction in which model is flying
  • Date and time
2.3 Log viewer
2.4 Log backup and sharing
3 Return To Home
  • in the Spirit Settings by choosing the best spot at the map
  • by transmitter command being at the place considered as a new Home.
3.1 Description
3.2 With Altitude Hold
4 Auto Landing
4.1 Description
5 Position Hold
5.1 Description
5.2 With Altitude Hold
6 Geo-fence
6.1 Description
6.2 With Altitude Hold
7 Altitude Hold
7.1 Description
8 Altitude Limit
8.1 Description
