Гувернер двигателя
Revision as of 13:17, 19 May 2021 by Gstatopen (Talk | contribs)
Гувернер Spirit (так называемый внешний гувернер) может использоваться со всеми приемниками, подключаемыми по однопроводному цифровому интерфейсу.
This mean that for PWM and PPM it cannot be used. To make it work, you will need to get a RPM Sensor which can supply the unit with current RPM data.
1 Wiring
1.1 Throttle
For usage of the Spirit Governor it is necessary to connect the Throttle (ESC or the Throttle servo) to the following port:
  • Spirit and μSpirit - AUX port
  • Spirit Pro and Spirit 2 - AUX1 port
  • Spirit RS - THR port
1.2 RPM signal
To make the governor work well it is very important to choose an appropriate RPM sensor. RPM sensor can be external or built-in in the ESC.
Cable that carry RPM signal must be always connected when Governor is used.
Connect RPM signal cable to the pin of the unit:
  • μSpirit - P pin - pin in the middle of P/E/A port
  • Spirit - PIT pin - pin in the middle of ELE/PIT/AIL port
  • Spirit Pro and Spirit 2 - PIT pin - pin in the middle of ELE/PIT/AIL port
  • Spirit RS - RPM pin - pin in the middle of EXT/RPM/E2 port
Sensor can be powered from any available Satellite port (SAT) or directly from a BEC. Satellite port is giving 3.3V, while BEC is operating usually at 5 - 8V.
1.3 Wiring example
2 Список протестированных датчиков
The following are known to work well.
Электродвигатели
ДВС
3 Activation
First from all basic settings are necessary so the governor can control the head speed correctly. Please review all the parameters prior any configuration.
Fine-Tuning - Holding Limit
5 Throttle Channel verification
6 Electric motors - ESC Setup
6.1 ESC Throttle Calibration
  1. Turn off Spirit Governor in order to perform Throttle Calibration.
  2. Set linear Throttle curve in your radio transmitter so that 0% and 100% throttle position matches with value of the Throttle bar in the Diagnostics tab. If it is not matching, use Subtrim function in your transmitter and/or Travel Adjustment function.
  3. Re-calibrate Throttle Range according the instructions of your ESC. In the most cases it can be configured by powering the model with throttle stick with 100% throttle and then by moving the stick down to 0%.
  4. Now you can enable Spirit Governor again.
6.2 ESC setup
7 Combustion motors - Throttle Servo Setup
9 Governor Setup Procedure
10 First start
11 Экстренное прерывание авторотации (Bailout)
Функция Bailout может быть полезна пилотам, исполняющим авторотацию. Эта функция позволяет при необходимости быстро вывести двигатель на рабочие обороты. Скорость раскрутки двигателя можно задать параметром Скорость раскрутки для Bailout в Дополнительно / Экспертные настройки.
Чтобы воспользоваться функцией, надо всего лишь настроить передатчик.
  • Когда вы делаете авторотацию, не включайте Throttle Hold.
  • Вместо этого используйте специальный тумблер, который установит полку газа в диапазоне 12-50%.
Info.png Если полка газа упадет ниже 12%, раскрутка ротора будет нормальной (медленная, как при взлете) .
12 Throttle Hold для авторотации (необязательно).
В случае, если для авторотации вы хотите пользоваться только одним тумблером Throttle Hold, выполните следующие действия:
  1. Установите полку газа для Throttle Hold на 12%. (Двигатель будет крутиться)
  2. Уменьшайте Основное/Гувернер/Диапазон газа - Мин. пока двигатель полностью не остановится.
  3. Увеличивайте Усилие раскрутки до тех пор, пока не получите быструю раскрутку при отщелкивании Throttle Hold.
13 Устранение проблем
  • Задержка между отщелкиванием Throttle Hold и пуском двигателя - двигатель начнет вращаться с задержкой.
Убедитесь, что Диапазон газа настроен правильно. Вы делали калибровку газа подключив ESC к Spirit?
Мы рекомендуем сбросить ESC к заводским настройкам. В большинстве случаев, диапазон газа в ESC по умолчанию соответствует предварительно настроенному диапазону в Spirit (1100 мкс - 1900 мкс).
Если диапазон настроен правильно, но задержка все равно еще присутствует, увеличивайте параметр Усилие раскрутки до тех пор, пока двигатель не начнет вращаться сразу после отщелкивании Throttle Hold.
  • После отщелкивания Throttle Hold, двигатель стартует рывком и поворачивает модель.
Уменьшайте параметр Усилие раскрутки до тех пор, пока рывок не исчезнет. Если вы заметите задержку перед раскруткой мотора, значение слишком низкое и проблема не может быть решена настройками Spirit.
Проверьте, поддерживает ли ESC настройку усилия раскрутки (Например Startup power в HobbyWing). Если это поддерживается, попробуйте уменьшить и проверить. В некоторых случаях может помочь другие настройки, например, тайминга или PWM, но сначала убедитесь, что настройки допустимы для вашего двигателя.
  • После нагруженных фигур обороты держатся выше требуемых длительное время.
Убедитесь, что диапазон газа для ESC или сервы настроен правильно. Обычно проблема вызвана превышением предела для полного газа, задаваемого Диапазон газа - Макс. Например, если полный газ в ESC запрограммирован на 1800 мкс, но Spirit настроен на 1900 мкс, тогда Spirit будет перегазовывать на 100 мкс. Таким образом, при высокой нагрузке, может пройти несколько секунд, пока значение опустится до 1800 мкс.
Правильное решение - перенастроить диапазон газа либо в ESC, либо в Spirit.
  • В логе полетов часто встречается "Сигнал датчика оборотов зашумлен".
Убедитесь, что соединение с датчиком оборотов двигателя надежное. Если датчик - отдельное устройство, подключите провода от источника бортового питания (особенно минусовой провод) как можно ближе к сигнальному проводу в разъеме Spirit. Использование ферритовых колец на питающих проводах также может снизить шум. Проверьте требования к рабочему напряжению для датчика. Некоторые датчики требуют 3,5 В или более, поэтому они не могут питаться от портов для сателлитов Spektrum. В некоторых случаях проблема вызвана слишком высоким значением Отклик гувернера, поэтому обороты двигателя начинают колебаться.
  • Гувернер не меняет обороты на разных полках газа
Диапазон газа в ESC откалиброван неправильно и не совпадает с установками в Spirit. Правильная калибровка диапазона в ESC решит проблему.
  • Сигнал датчика оборотов потерян.
Сигнал считается потерянным, если он не приходил в течение 2 секунд. Гувернер по-прежнему будет работать, но с ухудшением эффективности - аналогично V-кривой газа. Сигнал с датчика может пропасть из-за плохого соединения. По этой причине мы настоятельно рекомендуем использовать термоклей или другой способ крепления разъемов.
