Hott Integration
Revision as of 10:03, 31 January 2017 by Admin (Talk | contribs) (Entering the menu)
From version 2.3 the Spirit units support full integration with the Graupner HoTT transmitters. This mean that you can configure the Spirit units completely from your radio without need of a computer.
The integration can work with all HoTT receivers and radios except MZ-4 and MZ-8.
1 Wiring
To allow the integration you have to connect additional cable to your current setup. This cable will connect the Telemetry port of the receiver with the SYS port of the unit. So there should be two connections between unit and receiver for:
  • Channel transmission (PWM, PPM or SUMD)
  • Telemetry and Integration data
Use the Hott Integration cable available in our eshop. Connect it according the following steps:
  1. End where all wires are present in the servo connector should be connected to the receiver on the Telemetry port marked with T label.
  2. End with only orange and brown wires is connected to the SYS port.
Warning.png It is very important to pay attention during the connection!
If connected wrongly, it will damage the unit permanently. The cable end where Orange wire is in the middle pin must be always connected to the unit.
Info.png Servo connector in the Graupner Hott receivers is connected so that the signal wire is at the bottom.
2 Receiver configuration
Go to the Function (F)/Telemetry/Setting & Data View where you have to change option SENSOR at CHx to YES.
3 Entering the menu
Graupner MZ-18 - Integration menu
Graupner MZ-18 - General page
4 Sensor Emulation
By default the Spirit unit is emulating the General Air Module. In case that you are already using this module, you can change it to another in the integration menu. In the Advanced/Expert settings/HoTT Sensor you can change the module emulation.
5 Telemetry data
With the Spirit firmware 2.3.0 you are able to view:
  • Current RPM from the Governor.
  • Vibrations of the model (Reported as Fuel)
