Stabi mode
From version 2.3. it is possible to activate the Stabi/Function in the two ways:
- Negative Gyro Gain
- Separate channel (NEW)
1 Negative Gyro Gain
Gyro Gain is still used to set the rudder gyro gain. At the same time, positive or negative value will determine if selected function is inactive or active. So it is important to set the gyro gain properly for both normal flight and selected function. Usually same, but opposite values are fine (for example +60%/-60%)
- Position 0: 50% (normal flight)
- Position 1: -50% (selected function)
1.2 In the software
1.3 Function vs Gyro
| Function | Gyro gain | Gyro mode | Mode |
| Disabled | 0 - 100% | Head-Lock | - |
| Rescue (Normal) | 0 - 100% | Head-Lock | - |
| Rescue (Acro) | 0 - 100% | Head-Lock | - |
| Stabilisation (Normal) | 0 - 100% | Head-Lock | - |
| Stabilisation (Acro) | 0 - 100% | Head-Lock | - |
| Stabilisation (Scale) | 0 - 100% | Head-Lock | - |
| Coaxial | 0 - 100% | Head-Lock | - |
| Disabled | -100% - 0% | Normal (Rate) | - |
| Rescue (Normal) | -100% - 0% | Head-Lock | Rescue |
| Rescue (Acro) | -100% - 0% | Head-Lock | Rescue |
| Stabilisation (Normal) | -100% - 0% | Head-Lock | Stabilisation |
| Stabilisation (Acro) | -100% - 0% | Head-Lock | Stabilisation |
| Stabilisation (Scale) | -100% - 0% | Normal (Rate) | Stabilisation |
| Coaxial | -100% - 0% | Head-Lock | Stabilisation |
2 Separate channel
- Channel configuration
- Open the General/Channels.
- Function indicator
- 0 - function is inactive.
- 1 - function is active.
Gyro Gain can still change gyro mode (Head-Lock or Normal), but will not activate the Function in this configuration.
2.1 Function vs Channel
| Function | Channel | Mode |
| Disabled | 0 - 100% | - |
| Rescue (Normal) | 0 - 100% | - |
| Rescue (Acro) | 0 - 100% | - |
| Stabilisation (Normal) | 0 - 100% | - |
| Stabilisation (Acro) | 0 - 100% | - |
| Stabilisation (Scale) | 0 - 100% | - |
| Coaxial | 0 - 100% | - |
| Disabled | -100% - 0% | - |
| Rescue (Normal) | -100% - 0% | Rescue |
| Rescue (Acro) | -100% - 0% | Rescue |
| Stabilisation (Normal) | -100% - 0% | Stabilisation |
| Stabilisation (Acro) | -100% - 0% | Stabilisation |
| Stabilisation (Scale) | -100% - 0% | Stabilisation |
| Coaxial | -100% - 0% | Stabilisation |
2.2 Function vs Gyro
