Integrace HoTT
Od verze 2.3 jednotky Spirit podporují plnou integraci s vysílači Graupner HoTT. Znamená to, že lze konfigurovat jednotky Spirit zcela prostřednictvím rádia bez nutnosti připojení počítače.
Integrace funguje se všemi HoTT přijímači a vysílači kromě modelů MZ-4 a MZ-8.
[hide]1 Zapojení
To allow the integration you have to connect additional cable to your current setup. This cable will connect the Telemetry port of the receiver with the SYS port of the unit. So there should be two connections between unit and receiver for:
- Channel transmission (PWM, PPM or SUMD)
- Telemetry and Integration data
Use the Hott Integration cable available in our eshop. Connect it according the following steps:
- End with black servo connector should be connected to the receiver on the Telemetry port marked with T label.
- End with red servo connector should be connected to the SYS port.
It is very important to pay attention during the connection!
If connected wrongly, it will damage the unit permanently. The cable end where red wire is in the middle pin must be always connected to the unit. Never use other cables for this connection!
Servo connector in the Graupner Hott receivers is connected so that the signal wire is at the bottom.
2 Receiver configuration
Go to the Function (F)/Telemetry/Setting & Data View where you have to change option SENSOR at CHx to YES.
4 Sensor Emulation
Available types are:
- GAM - General Air Module
- EAM - Electric Air Module
5 Telemetry data
With the Spirit firmware 2.3.0 you are able to view:
- Current RPM from the Governor.
- Vibrations of the model (Reported as Fuel in the GAM)
