Translations:Align HE50H22 RPM Sensor/13/en
Revision as of 06:01, 18 February 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
If you are using Spektrum satellites, then instead of the Spektrum connector you will need second servo connector which can be powered from the BEC port. Make sure that the Black wire is in the middle of the Servo connector.
