Translations:Governor/34/en
Revision as of 09:44, 18 February 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
Check if the ESC supports a Spoolup Power parameter. If it is supported, then try to decrease the power and observe if it will help you. In some cases a different Timing or PWM frequency can help, but always make sure that the settings are valid for your motor.
