HobbyWing Telemetry
Revision as of 07:59, 21 April 2017 by Admin (Talk | contribs) (Created page with "HobbyWing Platinum V4 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necess...")
HobbyWing Platinum V4 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC as the older firmware versions were not supporting it.
1 Telemetry Cable
To allow the telemetry data transmission special cable is required. This cable is available in our Eshop.
2 Interfacing
Connect the Telemetry cable to the primary Spektrum satellite port in the unit. Unit-telemuni.jpg
Servo connector of the Telem UNI cable should be connected to the ESC - programming port (P). Esc-hw.jpg
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
