HobbyWing Telemetry
Revision as of 07:00, 21 April 2017 by Admin (Talk | contribs) (→‎Interfacing)
HobbyWing Platinum V4 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC as the older firmware versions were not supporting it.
1 Telemetry Cable
To allow the telemetry data transmission special cable is required. This cable is available in our Eshop.
2 Interfacing
Connect the Telemetry cable to the primary Spektrum satellite port in the unit.
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
