Scorpion Telemetry
Revision as of 07:14, 21 April 2017 by Admin (Talk | contribs) (Created page with "Scorpion Tribunus ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. == Telemetry Cable == To allow the telemetr...")
1 Telemetry Cable
2 Interfacing
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Scorpion Tribunus option.
4 Displaying telemetry data
