Kontronik Telemetry
Revision as of 07:46, 21 April 2017 by Admin (Talk | contribs) (Created page with "Kontronik KOSMIK and JIVE PRO ESC has telemetry feature built-in in dedicated telemetry port. This allows telemetry data transmission to the unit. {{Quote|'''This telemetry i...")
Warning.png This telemetry is available only for EX Bus connection with the Spirit firmware v2.4. In the future versions should work with other too.
1 Telemetry Cable
To allow the telemetry data transmission the Telem KONTRONIK cable is required. This cable is available in our Eshop.
2 Spirit Settings
First from all, power up the ESC and start the Spirit Settings as usually.
2.1 Telemetry activation
Set the ESC Telemetry in the Spirit Settings software.
Go to the Advanced/Telemetry settings and set the Kontronik KOSMIK & JIVE PRO option.
Then close the window and save the settings (CTRL+S). Now disconnect the battery.
3 Interfacing
At this step, connect the Telemetry cable according the following photo.
Note, that in this connection SYS port is used. Thus usage of this port for other purposes is limited when the Kontronik telemetry is enabled - more details above. ELE pin is utilized for communication purpose of the telemetry interface.
4 Displaying telemetry data
