Scorpion Telemetry
Revision as of 09:36, 21 April 2017 by Spiritdm (Talk | contribs)
Scorpion Tribunus ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit.
1 ESC configuration
To enable the ESC telemetry, it is necessary to set the Unsolicited telemetry mode in your ESC. With other modes the telemetry will not work. Change Communication protocol to Unsc Telem in the Scorpion Tribunus software. For this purpose Scorpion V link II Cable is needed.
2 Telemetry Cable
3 Interfacing
4.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Scorpion Tribunus option.
5 Displaying telemetry data
6 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
