ESC telemetry
The ESC telemetry is feature that allows you to display data from your Electronic Speed Controller (ESC) directly in your transmitter. Depending on transmitter capabilities you can Log the values and use them for a various purposes.
The ESC telemetry is mediated through the Spirit units (firmware v2.4+) as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
- JETI Duplex
- FrSky Taranis and Horus'
- Graupner HoTT
NOTE: These radios support full integration as well.
2 List of supported ESCs
- Castle Creations Phoenix & Talon
- HobbyWing Platinum V4
- Scorpion Tribunus
- Kontronik KOSMIK & JIVE PRO
3 Interfacing
4 Telemetry data
Available Telemetry variables are dependent on used ESC and Radio. Please refer to the section Supported models in particular page of the ESC. Spirit firmware v2.4 support up to 7 telemetry variables displayed at the single time. Future update will extend such possibilities.
- Battery Voltage
- Battery Current
- BEC Voltage - provided by ESC Telemetry or Receiver.
- Consumed Capacity - Battery Capacity consumed from the initialization point
- ESC Temperature - Usually temperature of the FET transistors.
- RPM - provided by RPM sensor (also with ESC Telemetry disabled)
- Vibes - provided by unit itself (also with ESC Telemetry disabled)
