ESC telemetry
Revision as of 09:42, 21 April 2017 by Admin (Talk | contribs) (→‎Telemetry data)
The ESC telemetry is feature that allows you to display data from your Electronic Speed Controller (ESC) directly in your transmitter. Depending on transmitter capabilities you can Log the values and use them for a various purposes.
The ESC telemetry is mediated through the Spirit units (firmware v2.4+) as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
  • JETI Duplex
  • FrSky Taranis and Horus'
  • Graupner HoTT
NOTE: These radios support full integration as well.
2 List of supported ESCs
3 Interfacing
4 Telemetry data
Spirit firmware v2.4 support up to 7 telemetry variables displayed at the single time. Future updates will extend such possibilities.
  • Battery Voltage
  • Battery Current
  • BEC Voltage - provided by ESC Telemetry or Receiver.
  • Consumed Capacity - Battery Capacity consumed from the initialization point.
  • ESC Temperature - Usually temperature of the FET transistors.
  • RPM - provided by RPM sensor (also with ESC Telemetry disabled)
  • Vibes - provided by unit itself (also with ESC Telemetry disabled)
