ESC telemetry
Revision as of 09:54, 21 April 2017 by Admin (Talk | contribs) (Telemetry data)
The ESC telemetry is feature that allows you to display data from your Electronic Speed Controller (ESC) directly in the transmitter. Depending on transmitter capabilities you can Log the values and use them for a various purposes.
The ESC telemetry is mediated through the Spirit units (firmware v2.4+) as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
  • JETI Duplex
  • FrSky Taranis and Horus'
  • Graupner HoTT
Info.png These radios support full integration as well.
2 List of supported ESCs
3 Interfacing
4 Telemetry data
  • Battery Voltage
  • Battery Current
  • BEC Voltage - provided by ESC Telemetry or Receiver.
  • Consumed Capacity - Battery Capacity consumed from the initialization point.
  • ESC Temperature - Usually temperature of the FET transistors.
  • Head Speed - provided by RPM sensor (also with ESC Telemetry disabled)
  • Vibration Level - provided by unit itself (also with ESC Telemetry disabled)
