ESC telemetrie
Revision as of 12:27, 21 April 2017 by Admin (Talk | contribs) (Created page with "ESC telemetrie je funkce, která umožní zobrazení dat regulátoru otáček (ESC) přímo ve vysílači. V závislosti na možnostech vysílače lze provádět záznam těch...")
ESC telemetrie je funkce, která umožní zobrazení dat regulátoru otáček (ESC) přímo ve vysílači. V závislosti na možnostech vysílače lze provádět záznam těchto dat, včetně pokročilých operací.
The ESC telemetry is mediated through the Spirit units (firmware v2.4+) as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
- JETI Duplex
- FrSky Taranis and Horus
- Graupner HoTT
2 List of supported ESCs
- Castle Creations Phoenix & Talon
- HobbyWing Platinum V4
- Scorpion Tribunus
- Kontronik KOSMIK & JIVE PRO
3 Interfacing
4 Telemetry data
- Battery Voltage [V]
- Battery Current [A]
- BEC Voltage [V] - provided by ESC Telemetry or Receiver.
- Consumed Capacity [mAh] - Battery Capacity consumed from the initialization point.
- ESC Temperature [°C] - Usually temperature of the FET transistors.
- Head Speed [RPM] - provided by RPM sensor (also with ESC Telemetry disabled)
- Vibration Level [%] - provided by unit itself (also with ESC Telemetry disabled)
