ESC telemetry
Revision as of 12:49, 21 April 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
The ESC telemetry is feature that allows you to display data from your Electronic Speed Controller (ESC) directly in the transmitter. Depending on transmitter capabilities you can Log the values and use them for a various purposes.
The ESC telemetry is mediated through the Spirit units (firmware v2.4+) as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
  • JETI Duplex
  • FrSky Taranis and Horus
  • Graupner HoTT
Info.png These radios support full integration as well.
2 List of supported ESCs
3 Interfacing
4 Telemetry data
  • Battery Voltage [V]
  • Battery Current [A]
  • Head Speed [RPM] - provided by RPM sensor (also with ESC Telemetry disabled)
